Introdução
The gear motor can break down over time. A common mistake is that one of the fastening eyes tears out. The machine then just rattles loudly. The motor must then be completely replaced.
Take the opportunity to revise the brew group and the drainage valve at the same time!
O que você precisa
Remove all attachments, such as the water reservoir, coffee grounds drawer, and bean compartment lid.
Remove all coffee beans.
Use the spudger to press in on both sides of the marked area. Then the front cover around the on / off switch is unlocked. You can then lift it up at the front and pull it out at an angle.
If the side openings for the spudger cannot be found, the model is slightly different. With this version you have to insert the spudger into the gap between the front panel and cover, about 3 cm from the edge and then push it firmly towards the center to unlock. At the same time, lift the cover a little at the front.
Unscrew the two T15 Torx screws that secure the side panels at the top.
The lock is located under the Jura badge on the back. Turn it counterclockwise about 20 degrees, then you can remove it.
Unfortunately, this one is very stuck. Nothing helped with this device, no suction cup or stiff adhesive tape. Here it is opened with a somewhat more rustic method:
Two small holes were drilled a few millimeters deep, then two small screws were screwed in. The badge could finally be turned and removed with a pair of pliers.
Lay the machine on its side.
Pry the side panel about 7 cm from the front edge, about 3 mm high. This will cause the catch to come out of its opening. Use a strong tool, preferably one made of plastic.
Position of the wedge-shaped notch: 7 cm from the front edge, 1.5 cm from the top or bottom edge.
Leave the tool in place. Insert an opening pick 7 cm from the front edge so that the wedge-shaped notch can no longer engage in its opening. Pull out the tool.
In the same way, insert another opening pick on the opposite edge.
The gear motor is located behind the electronics box. First this path has to be cleared.
Disconnect the cables on the top row. Be sure to note which connector is plugged in where.
Detach the cables on the left side as well
From the bottom row you only need to loosen the plug (here blue-red) that belongs to the motor.
Unscrew the three Torx T10 screws that hold the box in place.
Set the box aside.
Complete the steps in reverse order to reassemble your device.
Um agradecimento especial a esses tradutores:
100%
oldturkey03 está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Um comentário
Perfekt, viele Dank für die Instruktionen. Ich habe die Problem mit den Motor und es ist in Ordnung
