Ir para o conteúdo principal
Repairing nose pads on eyeglasses
O que você precisa
  1. Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: passo 1, imagem 1 %32 Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: passo 1, imagem 2 %32
    • Remove the screw from the pad arm.
    • If the screw is missing, get a backup screw, and proceed to step 2.
  2. Repairing nose pads on eyeglasses: passo 2, imagem 1 %32 Repairing nose pads on eyeglasses: passo 2, imagem 2 %32
    • Insert the nose pad into the mount on the frame.
    • Make sure the nose pad lines up with the screw hole.
    • While holding the nose pad in place, use the magnet to attract the screw head.
    • Make sure the screw is vertical to the magnet and the screw head is above.
  3. Repairing nose pads on eyeglasses: passo 3, imagem 1 %32
    • Place the screw into the screw hole.
  4. Repairing nose pads on eyeglasses: passo 4, imagem 1 %32 Repairing nose pads on eyeglasses: passo 4, imagem 2 %32
    • Using a horizontal motion, remove the magnet.
    • Don't use a vertical motion to remove the magnet, otherwise the screw will come out.
  5. Repairing nose pads on eyeglasses: passo 5, imagem 1 %32 Repairing nose pads on eyeglasses: passo 5, imagem 2 %32
    • Holding the glasses with the screw head pointing up, tighten the screw with the screwdriver.
    • Make sure the screw is tightened enough.
Conclusão
3 outras pessoas executaram este guia.
Vivi Chou
Membro desde: 04/28/17
151 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S3-G4, Coad Spring 2017 Membro de UC Davis, Team S3-G4, Coad Spring 2017
UCD-COAD-S17S3G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 72
Últimos 30 dias: 365
Duração total: 47,063
