Ir para o conteúdo principal
Repairing iPhone 4 dust mesh
O que você precisa
  1. Repairing iPhone 4 dust mesh, Repairing iPhone 4 dust mesh: passo 1, imagem 1 %32 Repairing iPhone 4 dust mesh, Repairing iPhone 4 dust mesh: passo 1, imagem 2 %32
    • Left image shows iPhone with missing front dust mesh
    • Right image shows dust meshes on bottom
  2. Repairing iPhone 4 dust mesh: passo 2, imagem 1 %32 Repairing iPhone 4 dust mesh: passo 2, imagem 2 %32
    • Cut out a piece of stainless steel mesh of the tea filter using a pocket knife
    • Trim the piece of mesh using a pair of scissors to a size of approx. 3x9 mm
  3. Repairing iPhone 4 dust mesh: passo 3, imagem 1 %32 Repairing iPhone 4 dust mesh: passo 3, imagem 2 %32
    • Fold the piece of mesh longways using the plastic tip
    • Use a pair of tweezers to insert the folded piece of mesh into the hole above the speaker
    • Put piece of mesh into place using plastic tip
    • That's it - see the result on the images
Linha de Chegada
28 outras pessoas executaram este guia.
aiwo
Membro desde: 03/13/12
2.286 Reputação
Autoria de 1 guia
Um comentário
This may work fine for most dirt, but with the original design there is also a cloth mesh behind the metal mesh that helps to keep finer particles out of the speaker.
This is definitely a much much much easier way to get some sort of protection in there at least. :)
Rene Jeddore - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 17
Duração total: 50,269
