Ir para o conteúdo principal
Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount
O que você precisa
  1. Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Remove the cap from the mount: passo 1, imagem 1 %32 Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Remove the cap from the mount: passo 1, imagem 2 %32 Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Remove the cap from the mount: passo 1, imagem 3 %32
    • Use your cutter knife to pry open the small cap that hides the inner contacts.
    • You probably have to go a bit deeper into the plastic as the cap is glued to the casing.
  2. Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Prepare the cable: passo 2, imagem 1 %32 Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Prepare the cable: passo 2, imagem 2 %32 Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Prepare the cable: passo 2, imagem 3 %32
    • Take the remaining cable and remove some of the thick black insulation as well as some of the thin insulation as shown in the picture.
    • Remove the broken cable by ripping it off carefully or using a soldering iron.
  3. Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Solder the cable to the contacts: passo 3, imagem 1 %32 Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Solder the cable to the contacts: passo 3, imagem 2 %32
    • Use the paper clip to hold the cable at the right position.
    • Solder the prepared cable to the contacts.
    • Remember: the red cable left, the black cable right.
    • The contacts take up heat of the soldering iron really fast. This can lead to the contacts melting the surrounding plastic. Hence, you have to be fast.
  4. Repairing a ripped off cable of a Sigma ATS and STS cyclometer mount, Glue the cap to the mount: passo 4, imagem 1 %32
    • Apply some glue to the mount and re-attach the cap to the mount.
Conclusão
Now go and attach the cyclometer to your bike and check that it works again.
4 outras pessoas executaram este guia.
Baschtl
Membro desde: 12/02/12
1.405 Reputação
5 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 918
