Ir para o conteúdo principal
Repairing a Wobbly Piano Bench
O que você precisa
  1. Repairing a Wobbly Piano Bench, Repairing a Wobbly Piano Bench: passo 1, imagem 1 %32
    • Place the bench on an even surface.
  2. Repairing a Wobbly Piano Bench: passo 2, imagem 1 %32
    • Open and lock its lid. Make sure it stays open during the whole procedure.
  3. Repairing a Wobbly Piano Bench: passo 3, imagem 1 %32 Repairing a Wobbly Piano Bench: passo 3, imagem 2 %32 Repairing a Wobbly Piano Bench: passo 3, imagem 3 %32
    • Unscrew the outer hex nut from one leg using the wrench and take the lock washer out.
  4. Repairing a Wobbly Piano Bench: passo 4, imagem 1 %32 Repairing a Wobbly Piano Bench: passo 4, imagem 2 %32 Repairing a Wobbly Piano Bench: passo 4, imagem 3 %32
    • Take the leg out and unscrew the inner hex nut.
    • Replace the washers with the new ones and re-screw the hex nut tightly.
  5. Repairing a Wobbly Piano Bench: passo 5, imagem 1 %32
    • Connect the leg to the bench again using the new lock washer.
    • Screw the hex nut a few rounds, but do not tighten it yet.
    • Repeat Steps 3 through 5 for all four legs.
  6. Repairing a Wobbly Piano Bench: passo 6, imagem 1 %32 Repairing a Wobbly Piano Bench: passo 6, imagem 2 %32
    • Add a little weight to the chair or push it down with two hands.
    • Turn all four outer hex nuts one round.
    • Make sure the bench is balanced and repeat until all hex nuts are tight.
  7. Repairing a Wobbly Piano Bench: passo 7, imagem 1 %32 Repairing a Wobbly Piano Bench: passo 7, imagem 2 %32
    • Close the lid seat on the chair.
    • If the chair is not balanced or if it makes noises, unscrew the outer nut two rounds and repeat Step 6.
Conclusão
You can redo this process every 6 months to make sure your bench is always stable.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,089
