Ir para o conteúdo principal
Repairing a Panasonic SA-HT810V with the H02/H07 error
O que você precisa
  1. Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: passo 1, imagem 1 %32 Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: passo 1, imagem 2 %32 Repairing a Panasonic SA-HT810V with the H02/H07 error, Repairing a Panasonic SA-HT810V with the H02/H07 error: passo 1, imagem 3 %32
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. Repairing a Panasonic SA-HT810V with the H02/H07 error: passo 2, imagem 1 %32 Repairing a Panasonic SA-HT810V with the H02/H07 error: passo 2, imagem 2 %32
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  3. Repairing a Panasonic SA-HT810V with the H02/H07 error: passo 3, imagem 1 %32
    • Before removing top cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Repairing a Panasonic SA-HT810V with the H02/H07 error: passo 4, imagem 1 %32 Repairing a Panasonic SA-HT810V with the H02/H07 error: passo 4, imagem 2 %32
    • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
    • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
Conclusão
Uma outra pessoa concluiu este guia.
Nathan Cheadle
Membro desde: 04/15/10
161 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 16-5, Maness Spring 2010 Membro de Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
Membros da 4
Autoria de 7 guias
3 comentários
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
Jerry Wayock - Responder
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
Mark Zarraonandia - Responder
Can’t get screws undone on ours… Help!
Matthew - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 35
Duração total: 27,957
