Ir para o conteúdo principal
Repairing a Nova waffle iron
  1. Repairing a Nova waffle iron, Check the electrical connections in the socket: passo 1, imagem 1 %32 Repairing a Nova waffle iron, Check the electrical connections in the socket: passo 1, imagem 2 %32
    • Open the socket to check the connections.
    • This wire connection should be reconnected.
  2. Repairing a Nova waffle iron, Open one side of the device: passo 2, imagem 1 %32 Repairing a Nova waffle iron, Open one side of the device: passo 2, imagem 2 %32 Repairing a Nova waffle iron, Open one side of the device: passo 2, imagem 3 %32
    • Open one side of the device.
    • Remove the protective plate.
    • Remove the old mica-flakes.
  3. Repairing a Nova waffle iron, Renew the cable lugs: passo 3, imagem 1 %32 Repairing a Nova waffle iron, Renew the cable lugs: passo 3, imagem 2 %32 Repairing a Nova waffle iron, Renew the cable lugs: passo 3, imagem 3 %32
    • Install new cable ends and cable lugs.
  4. Repairing a Nova waffle iron, Replace the mica-sheet: passo 4, imagem 1 %32
    • Cut new mica sheets to size. These form an electrical insulator and at the same time a heat conductor with the protective plate.
    • Assemble the protective plate and mount this side back on the waffle iron.
    • Repeat these steps on the other side of the waffle maker.
  5. Repairing a Nova waffle iron, Put the waffle iron back together: passo 5, imagem 1 %32
    • Follow the instructions in reverse order to reassemble the waffle iron.
    • Now get to work... baking waffles the grandmotherly way! Enjoy your meal!
Conclusão
To reassemble the device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
nl en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Pierre
Membro desde: 04/02/13
542 Reputação
Autoria de 3 guias
9 comentários
Dag Pierre, ik heb een identiek of zeer vergelijkbaar wafelijzer model dat ik probeer te repareren na wat leek op een intern kortsluiting evenement. Je gids ziet er heel duidelijk uit!
Ik zit weliswaar een beetje vast met de mica vellen die vervangen moeten worden. Het is me niet meteen duidelijk aan de schilfers van de huidige vellen hoeveel lagen er juist in zaten of horen te zitten. Is dit slechts 1 laag per kant? Daarnaast zijn bij mij de schilfers net zoals op je foto transparant, maar de nieuwe vellen niet?
Ik ben ook niet bekend met dit product dus ik weet niet goed waar ik op moet letten(eigenschappen als dikte, isolerend/warmtegeleidende eigenschappen,…?) als ik nieuwe vellen koop en waar ik deze best en redelijk goedkoop kan kopen (lokale hobbywinkel als een Brico/Gamma of eerder een webshop?).
Alvast bedankt voor je feedback!
Matthias Duyck - Responder
Dag Matthias,
Vooreerst bedankt voor je complimenten. Ik vermoed dat je de oude mica schilfers terug mag gebruiken, dat zou normaal geen probleem mogen zijn. Zelf heb ik die mica vellen gevonden via een lange zoektocht op internet en weet even niet uit het hoofd waar ik die vond. Zeker niet in een gewone doe het zelf zaak. Ik kijk in de loop van deze week eens of ik die gegevens terug vind.
Mvg, Pierre
Pierre -
Dag Matthias, de firma COGEBI in LOT (Halle) heeft allerlei mica producten.
Mvg, Pïerre.
Pierre -
Beste, waar kan ik nog onderdelen vinden voor een nova wafelijzer type 10?
masse.vdp - Responder
Ik ben ook op zoek naar verwisselbare platen voor galettekes en Brusselse wafels voor de Nova 10.
veerle.audenaert -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 22
Duração total: 2,726
