Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
In this guide, you will learn how to fix a loose pan handle. This will be done by removing the handle, cleaning the handle base, and repairing any warps. A warp is when the metal bends out of shape. This does not work on cast iron, since the handle does not come off.
Peças
Nenhum componente especificado.
  1. Identify the screw keeping the handle in place. Most screws are located on the underside, and a typical pan has only one screw. If there are more, locate them as well. Use a standard Phillips screwdriver to remove the screw(s).
    • Identify the screw keeping the handle in place.
    • Most screws are located on the underside, and a typical pan has only one screw. If there are more, locate them as well.
    • Use a standard Phillips screwdriver to remove the screw(s).
  2. Remove the handle and the metal bar to expose the base of the pan handle. The base is where the full handle and the pan meet. The base is where the full handle and the pan meet.
    • Remove the handle and the metal bar to expose the base of the pan handle.
    • The base is where the full handle and the pan meet.
  3. Determine what kind of cleaning is required. I used a Lysol solution, which can be substituted with soap and water. If there is rust or burn marks, there are two guides on iFixit by other creators that work well. Their links can be followed by their respective words. Apply your cleaning solution to the base.
    • Determine what kind of cleaning is required. I used a Lysol solution, which can be substituted with soap and water.
    • If there is rust or burn marks, there are two guides on iFixit by other creators that work well. Their links can be followed by their respective words.
    • Apply your cleaning solution to the base.
    • If necessary, apply cleaning solution to the handle and metal bar, as well.
    • Wipe the area until it is clean, repeat if necessary.
  4. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  5. Identify the warp on the pan, if any. Warps can impact the handle, making it loose or rest incorrectly. This can occur with even small warps, so look closely at your pan.
    • Identify the warp on the pan, if any.
    • Warps can impact the handle, making it loose or rest incorrectly. This can occur with even small warps, so look closely at your pan.
    • Set the pan on top of a flat cloth.
    • If the warp is going in towards the pan, lay it down with the inside of the pan facing up. If the warp is going out away from the pan, lay it down with the bottom of the pan facing up.
  6. If you do not use cloths, you will scratch the pan when you do Step 6.
    • If you do not use cloths, you will scratch the pan when you do Step 6.
    • Cover the warp with a second cloth. We used a different dish towel.
  7. Do not hammer too forcefully otherwise the pan will warp the opposite way.
    • Do not hammer too forcefully otherwise the pan will warp the opposite way.
    • Hammer the warp carefully.
    • It should take 2-3 strikes for smaller warps and more than 3 for bigger warps.
  8. Take the metal bar and place it back over the base. Take the metal bar and place it back over the base.
    • Take the metal bar and place it back over the base.
  9. Align the handle onto the metal bar. Push the handle into the metal bar socket. Put the screw back in the socket.
    • Align the handle onto the metal bar.
    • Push the handle into the metal bar socket.
    • Put the screw back in the socket.
    • Use the screw driver to tighten the screw.
    • To make sure it's not too loose, pick it up by the handle to test it. If it wobbles it is too loose, and needs to be tightened more.
Conclusão
Repeat this for any number of pans.
Augustus Gunnerson
Membro desde: 18/02/2020
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S1-G2, Andersen Winter 2020 Membro de UC Davis, Team S1-G2, Andersen Winter 2020
UCD-ANDERSEN-W20S1G2
3 Membros
1 Guia de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 85
