Ir para o conteúdo principal
Repairing a Dried-Out Sharpie Marker
O que você precisa
  1. Repairing a Dried-Out Sharpie Marker, Repairing a Dried-Out Sharpie Marker: passo 1, imagem 1 %32 Repairing a Dried-Out Sharpie Marker, Repairing a Dried-Out Sharpie Marker: passo 1, imagem 2 %32
    • Remove the cap of the Sharpie.
  2. Repairing a Dried-Out Sharpie Marker: passo 2, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 2, imagem 2 %32 Repairing a Dried-Out Sharpie Marker: passo 2, imagem 3 %32
    • Use a pair of pliers to separate the black part from the grey part of the Sharpie.
    • This can be a little difficult, so you may need to use two pairs of pliers to pull them apart.
  3. Repairing a Dried-Out Sharpie Marker: passo 3, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 3, imagem 2 %32
    • Pull out the ink pad.
    • Only touch the sides of the ink pad so that you do not get ink on yourself.
  4. Repairing a Dried-Out Sharpie Marker: passo 4, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 4, imagem 2 %32
    • Draw the rubbing alcohol into the syringe.
  5. Repairing a Dried-Out Sharpie Marker: passo 5, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 5, imagem 2 %32 Repairing a Dried-Out Sharpie Marker: passo 5, imagem 3 %32
    • Drip the rubbing alcohol into the part of the ink pad that has a sponge with a hole in its center. Do this until the sponge seems saturated (or about 5 drops).
  6. Repairing a Dried-Out Sharpie Marker: passo 6, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 6, imagem 2 %32
    • Put the ink pad back in.
  7. Repairing a Dried-Out Sharpie Marker: passo 7, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 7, imagem 2 %32 Repairing a Dried-Out Sharpie Marker: passo 7, imagem 3 %32
    • Put the black part and grey part of the Sharpie back together.
  8. Repairing a Dried-Out Sharpie Marker: passo 8, imagem 1 %32 Repairing a Dried-Out Sharpie Marker: passo 8, imagem 2 %32
    • Put the cap of the Sharpie back on.
  9. Repairing a Dried-Out Sharpie Marker: passo 9, imagem 1 %32
    • Let the Sharpie set for 1-3 minutes.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 30
Últimos 30 dias: 65
Duração total: 1,050
