Ir para o conteúdo principal
Repairing a Broken or Loose Paper Towel Hanger
O que você precisa
  1. Repairing a Broken or Loose Paper Towel Hanger, Repairing a Broken or Loose Paper Towel Hanger: passo 1, imagem 1 %32
    • Detach the paper towel hanger from where it is attached.
    • Place it on a flat surface under sufficient light.
  2. Repairing a Broken or Loose Paper Towel Hanger: passo 2, imagem 1 %32 Repairing a Broken or Loose Paper Towel Hanger: passo 2, imagem 2 %32 Repairing a Broken or Loose Paper Towel Hanger: passo 2, imagem 3 %32
    • Inspect the paper towel hanger for loose components.
    • Identify the screw that is making the paper towel loose.
  3. Repairing a Broken or Loose Paper Towel Hanger: passo 3, imagem 1 %32 Repairing a Broken or Loose Paper Towel Hanger: passo 3, imagem 2 %32 Repairing a Broken or Loose Paper Towel Hanger: passo 3, imagem 3 %32
    • Take a screwdriver with a flat head to remove the loose screw.
    • Insert the screwdriver into the loose screw and rotate anti-clockwise to remove the loose screw.
  4. Repairing a Broken or Loose Paper Towel Hanger: passo 4, imagem 1 %32 Repairing a Broken or Loose Paper Towel Hanger: passo 4, imagem 2 %32 Repairing a Broken or Loose Paper Towel Hanger: passo 4, imagem 3 %32
    • Get a replacement screw of the same size and insert it into the area where the old screw was.
    • Line both parts of the paper towel hanger up and secure the new screw with the 3 mm Flathead screwdriver until it's snug.
  5. Repairing a Broken or Loose Paper Towel Hanger: passo 5, imagem 1 %32 Repairing a Broken or Loose Paper Towel Hanger: passo 5, imagem 2 %32 Repairing a Broken or Loose Paper Towel Hanger: passo 5, imagem 3 %32
    • Check to see if the paper towel hanger is now firm and secure.
    • Reattach the paper towel hanger to the wall.
Conclusão
In conclusion, this 'Paper Towel Hanger Repair Guide' empowers you to address a common household issue efficiently and safely. By following these steps and using the recommended tools, you can restore your hanger's functionality and ensure peace of mind.
Nziza Ngango
Membro desde: 09/08/23
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 279
