Ir para o conteúdo principal
Repairing a Broken Ceramic Pot
O que você precisa
  1. Repairing a Broken Ceramic Pot, Repairing a Broken Ceramic Pot: passo 1, imagem 1 %32
    • Gather all fragmented pieces of the broken pot.
    • Caution: Be careful handling broken pieces. Edges might be sharp.
  2. Repairing a Broken Ceramic Pot: passo 2, imagem 1 %32
    • Assemble each fragment of the pot temporarily to understand where each piece goes.
  3. Repairing a Broken Ceramic Pot: passo 3, imagem 1 %32
    • Clean the edges of the pot and its fragments with a clean cloth or paper towel.
  4. Repairing a Broken Ceramic Pot: passo 4, imagem 1 %32
    • Apply a small amount of Waterproof Gorilla Glue to the edges of the broken pot.
    • Gorilla Glue recommends 1 dot per square inch.
    • Caution: Do not touch glue with fingers. Wear gloves for extra precaution.
  5. Repairing a Broken Ceramic Pot: passo 5, imagem 1 %32 Repairing a Broken Ceramic Pot: passo 5, imagem 2 %32
    • Carefully fit the fragmented piece along the glued area and hold it firmly for 10-45 seconds.
  6. Repairing a Broken Ceramic Pot: passo 6, imagem 1 %32
    • Glue the inside of the pot for extra coverage and hold.
    • Repeat this process for other broken pieces, if any.
  7. Repairing a Broken Ceramic Pot: passo 7, imagem 1 %32
    • Let the glue set for at least 24 hours.
Conclusão
Repeat steps as needed until your pot is fully reassembled.
Uma outra pessoa concluiu este guia.
Christina Liles
Membro desde: 09/20/21
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 65
Últimos 30 dias: 285
Duração total: 4,427
