Ir para o conteúdo principal
Repairing VTech Touch and Swipe Baby Phone Screen Alignment
O que você precisa
  1. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: passo 1, imagem 1 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Battery: passo 1, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 2, imagem 1 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 2, imagem 2 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 2, imagem 3 %32
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 3, imagem 1 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 3, imagem 2 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 3, imagem 3 %32
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 4, imagem 1 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 4, imagem 2 %32
    • Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
  5. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 5, imagem 1 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 5, imagem 2 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 5, imagem 3 %32
    • Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
  6. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 6, imagem 1 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 6, imagem 2 %32
    • Remove two 7.2 mm screws with a Phillips #0 screwdriver.
    • Slide off the spring.
  7. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 7, imagem 1 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 7, imagem 2 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 7, imagem 3 %32
    • Remove the single 7.5mm screw with a Phillips #0 screwdriver.
    • Lift up the black plastic piece.
  8. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 8, imagem 1 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 8, imagem 2 %32
    • Remove four 7.5mm screws with a Phillips #0 screwdriver.
  9. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 9, imagem 1 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 9, imagem 2 %32
    • Remove the two buttons, noting how wires are placed for reassembly.
  10. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 10, imagem 1 %32 Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 10, imagem 2 %32
    • Lift the button board up and away to clear room for lifting the motherboard.
    • Tilt the assembly up but being wary that it is still attached to the front panel.
  11. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 11, imagem 1 %32
    • Slide the toothed slider towards you to remove.
  12. Repairing VTech Touch and Swipe Baby Phone Screen Alignment: passo 12, imagem 1 %32
    • To reassemble, align the two black lines together by moving the belt back and forth.
    • Once aligned reinsert the toothed slider at the exact point shown.
    be careful at the top blue button (on/off) that might come off when you align the belt
    cipriansoleriu - Responder
Conclusão
To reassemble your device, follow these instructions in reverse order, skipping step 10 as the toothed slider has already been put in for proper alignment.
Uma outra pessoa concluiu este guia.
Sean Webb
Membro desde: 09/04/15
384 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-4, Sullivan Fall 2015 Membro de USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
Membros da 3
Autoria de 12 guias
Um comentário
Good work !
Nice.
I did not see the black line in mine,
i opened the foil and glued it new together . Not so nice. :D
But it works.
Schwarzstein - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,286
