Ir para o conteúdo principal
Repairing Turtle Beach PX22 Sticky Volume Wheels
O que você precisa
  1. Repairing Turtle Beach PX22 Sticky Volume Wheels, Repairing Turtle Beach PX22 Sticky Volume Wheels: passo 1, imagem 1 %32 Repairing Turtle Beach PX22 Sticky Volume Wheels, Repairing Turtle Beach PX22 Sticky Volume Wheels: passo 1, imagem 2 %32
    • Remove the 4 screws from the inline amplifier using a #6 torque screwdriver head. The screws measure 1/4" long and 3/32" in diameter.
    • Open the amplifier by using the smaller plastic opening tool. Place it in the headphone jack and use leverage to pry open the plastic halves.
    • Be aware of the small plastic cylinder that braces the headphone jack.
  2. Repairing Turtle Beach PX22 Sticky Volume Wheels: passo 2, imagem 1 %32 Repairing Turtle Beach PX22 Sticky Volume Wheels: passo 2, imagem 2 %32
    • Remove the circuit board from the plastic housing and flip it so that you can see the scroll wheels.
    • Using a cloth dipped in isopropyl rubbing alcohol, clean the affected scroll wheels.
    • 90-100% isopropyl alcohol is preferred for cleaning.
  3. Repairing Turtle Beach PX22 Sticky Volume Wheels: passo 3, imagem 1 %32 Repairing Turtle Beach PX22 Sticky Volume Wheels: passo 3, imagem 2 %32 Repairing Turtle Beach PX22 Sticky Volume Wheels: passo 3, imagem 3 %32
    • When done cleaning, place the circuit board back in the plastic housing.
    • The scroll wheels should be facing the housing with the logo and labels, and should slide onto the 4 screw holes.
    • Make sure the plastic headphone jack brace is in position.
    • Position the wire in the slot on the other side of the amplifier, it should slide down onto the housing and become fixed.
    • Close the housing with the other plastic half. It will click into place.
    • Replace the 4 screws using the #6 torque screwdriver.
Conclusão
Equipe
UMass Dartmouth, Team 3-1, Duarte Spring 2015 Membro de UMass Dartmouth, Team 3-1, Duarte Spring 2015
UMASSD-DUARTE-S15S3G1
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 1,444
