Ir para o conteúdo principal
Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System
O que você precisa
Vídeo de Apresentação
  1. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System, Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 1, imagem 1 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System, Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 1, imagem 2 %32
    • Switch-off the laptop and remove the battery.
  2. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 2, imagem 1 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 2, imagem 2 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 2, imagem 3 %32
    • To remove the Keyboard you must open 7x locking clips.
    • You can use a cutter and a plastic tool.
  3. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 3, imagem 1 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 3, imagem 2 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 3, imagem 3 %32
    • Remove the Keyboard.
    • Remove the HDD, RAM Memory cover.
  4. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 4, imagem 1 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 4, imagem 2 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 4, imagem 3 %32
    • Remove the HDD and the DVD optical drive.
  5. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 5, imagem 1 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 5, imagem 2 %32
    • Unscrew the screws from the upper and the bottom cases.
  6. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 6, imagem 1 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 6, imagem 2 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 6, imagem 3 %32
    • With a plastic tool you can separate the bottom case from the laptop.
  7. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 7, imagem 1 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 7, imagem 2 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 7, imagem 3 %32
    • Disconnect the CPU fan cable connector.
    • Now you have 4x screws on the CPU side and 2x on the fan.
  8. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 8, imagem 1 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 8, imagem 2 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 8, imagem 3 %32
    • Separate the fan from the radiator.
    • Clean the radiator and the fan. Use a soft brush.
  9. Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 9, imagem 1 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 9, imagem 2 %32 Repairing Toshiba Satellite C850 - Cleaning the Cooling / Fan System: passo 9, imagem 3 %32
Conclusão
15 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.368 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.464 guias
8 comentários
Very good, thank you. :-)
andymcleod - Responder
I' thank you too. :)
ZFix -
Absolutely awesome job!
Thanks a plenty.
SolaJ
SolarJ - Responder
Can't you just leave fan assembly installed and start cleaning it with brush and compressed air once you have bottom case cover off? What about just blowing air thru the grill covering the fan and not even removing the bottom case cover?
bikeboatski - Responder
I just red it and found it's not for me. But i still felt I'd instantly send $1 to the author, besides those points, which i do not care of.
So I suggest to FIXIT.COM to offer it optionally. I meean... Optinally if you want you may send $1 or more to the author.... and I would put "1" ass default. I want it tobe JUST ONE CLICK. Otherwise I leave.
Jon Pol - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 56
Duração total: 32,093
