Ir para o conteúdo principal
Repairing Tire Hole/Puncture
O que você precisa
  1. Repairing Tire Hole/Puncture, Repairing Tire Hole/Puncture: passo 1, imagem 1 %32
    • Wipe the surface of the tire with a rag to remove any loose dirt, rocks, or debris.
  2. Repairing Tire Hole/Puncture: passo 2, imagem 1 %32
    • Using the air compressor, air the tire up to the original recommended weight for the vehicle.
    • Air is expected to continue to leak out so do not worry if you cannot get it perfect.
  3. Repairing Tire Hole/Puncture: passo 3, imagem 1 %32 Repairing Tire Hole/Puncture: passo 3, imagem 2 %32
    • Use the air pressure gauge to make sure the tire is now aired up to its original pressure.
  4. Repairing Tire Hole/Puncture: passo 4, imagem 1 %32
    • Spray the surface of the tire completely with the soapy water.
  5. Repairing Tire Hole/Puncture: passo 5, imagem 1 %32
    • Look for tiny air bubbles forming from the leaking air and soap combination, this is where the hole is located.
  6. Repairing Tire Hole/Puncture: passo 6, imagem 1 %32 Repairing Tire Hole/Puncture: passo 6, imagem 2 %32 Repairing Tire Hole/Puncture: passo 6, imagem 3 %32
    • Once the hole is located, remove any foreign objects with the pliers if present.
    • Any object that is stuck in the tire, or puncturing the tire is considered a foreign object. These may include sharp objects, commonly seen as nails, screws, or pieces of metal.
  7. Repairing Tire Hole/Puncture: passo 7, imagem 1 %32
    • Insert the reamer into the puncture.
    • Work the reamer in and out while twisting to clean and prep the puncture.
  8. Repairing Tire Hole/Puncture: passo 8, imagem 1 %32
    • Put the plug into the insertion tool.
  9. Repairing Tire Hole/Puncture: passo 9, imagem 1 %32
    • Insert the plug into the punctured area, leaving about ¼ inch of the plug above the surface of the tire.
    • Yank the insertion tool so the plug remains in the tire, but the tool releases.
    • Cut the remaining plug so it is flush with the tire.
  10. Repairing Tire Hole/Puncture: passo 10, imagem 1 %32
    • Refill the tire to the proper pressure.
  11. Repairing Tire Hole/Puncture: passo 11, imagem 1 %32 Repairing Tire Hole/Puncture: passo 11, imagem 2 %32
    • Use the air pressure gauge to make sure that the tire is back to its original air pressure.
Conclusão
4 outras pessoas executaram este guia.
Jaylynn Hoffman
Membro desde: 10/27/15
266 Reputação
Autoria de 1 guia
Equipe
Um comentário
i work at discount tire and this is not a department of transportation approved fix and and repuidiple tire dealer will tell you they cannot put a tire back on if they notice this
redheadmateo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 95
Duração total: 5,396
