Ir para o conteúdo principal
Revlon 473 Hair Dryer Switch Replacement
O que você precisa
  1. Revlon 473 Hair Dryer Switch Replacement, Shell: passo 1, imagem 1 %32
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Hair Dryer Switch Replacement: passo 2, imagem 1 %32
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Hair Dryer Switch Replacement: passo 3, imagem 1 %32 Revlon 473 Hair Dryer Switch Replacement: passo 3, imagem 2 %32 Revlon 473 Hair Dryer Switch Replacement: passo 3, imagem 3 %32
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Hair Dryer Switch Replacement, Switch: passo 4, imagem 1 %32
    • Locate the two switches in the handle of the device.
  5. Revlon 473 Hair Dryer Switch Replacement: passo 5, imagem 1 %32
    • Set the multimeter to 200 ACV.
  6. Revlon 473 Hair Dryer Switch Replacement: passo 6, imagem 1 %32
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
    • To replace a faulty switch, cut the wires and solder the wires back on to the new switch.
Conclusão
Uma outra pessoa concluiu este guia.
Jessica Leyva
Membro desde: 09/18/12
143 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 1-5, Propen Fall 2012 Membro de Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 33
Duração total: 1,821
