Ir para o conteúdo principal
Repairing Quasar Microwave Door Handle
O que você precisa
  1. Repairing Quasar Microwave Door Handle, Disassembling Quasar Microwave Outer Cover: passo 1, imagem 1 %32
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Door Handle: passo 2, imagem 1 %32 Repairing Quasar Microwave Door Handle: passo 2, imagem 2 %32
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Door Handle: passo 3, imagem 1 %32 Repairing Quasar Microwave Door Handle: passo 3, imagem 2 %32
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Door Handle: passo 4, imagem 1 %32 Repairing Quasar Microwave Door Handle: passo 4, imagem 2 %32 Repairing Quasar Microwave Door Handle: passo 4, imagem 3 %32
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Door Handle, Repairing Quasar Microwave Door Handle: passo 5, imagem 1 %32 Repairing Quasar Microwave Door Handle, Repairing Quasar Microwave Door Handle: passo 5, imagem 2 %32
    • Observe the lever mechanism found just behind the door handle, inside the microwave.
    • The plastic lever should be above the metal lever. If the metal lever is above the plastic lever, this is why the door will not open.
    • In this picture, the metal part is ABOVE the white plastic part. The white part needs to be lifted to open the door so when the door lever is pressed, the metal part rises, and the plastic part stays in place.
  6. Repairing Quasar Microwave Door Handle: passo 6, imagem 1 %32 Repairing Quasar Microwave Door Handle: passo 6, imagem 2 %32 Repairing Quasar Microwave Door Handle: passo 6, imagem 3 %32
    • Lift up on the outside lever.
    • Push up on the white plastic piece.
    • Push metal bar down, snapping the white plastic piece above it.
  7. Repairing Quasar Microwave Door Handle: passo 7, imagem 1 %32 Repairing Quasar Microwave Door Handle: passo 7, imagem 2 %32
    • This is how the fixed mechanism should look.
    • Press the button and enjoy your newly fixed door!
Conclusão
Uma outra pessoa concluiu este guia.
Samuel
Membro desde: 09/26/12
142 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-12, Propen Fall 2012 Membro de Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 1,988
