Ir para o conteúdo principal
Repairing Puppet Strings
O que você precisa
  1. Repairing Puppet Strings, Repairing Puppet Strings: passo 1, imagem 1 %32
    • Detach the severed/damaged strings. This can be done by cutting them or carefully pulling them out.
  2. Repairing Puppet Strings: passo 2, imagem 1 %32
    • Thread the fishing line through the needle as you would with thread and tie a simple knot to secure the fishing line.
    • Note: Tying the knot can be tedious, so it may take a few tries.
  3. Repairing Puppet Strings: passo 3, imagem 1 %32
    • Insert the needle into a secure part of the puppet's feet or other necessary puppet part.
    • Note: The material may resist the needle at first.
  4. Repairing Puppet Strings: passo 4, imagem 1 %32 Repairing Puppet Strings: passo 4, imagem 2 %32
    • Pull the needle through the puppet part and tie another simple knot directly onto the location that was threaded through.
    • Note: You may want to tie a few simple knots for extra security.
  5. Repairing Puppet Strings: passo 5, imagem 1 %32
    • If you need to make a handle, take the two wooden sticks and cross them to where they are perpendicular to each other.
  6. Repairing Puppet Strings: passo 6, imagem 1 %32
    • Secure the two sticks with tape or glue where the two sticks cross.
    • Note: Tape is a faster fix, but may appear messier.
  7. Repairing Puppet Strings: passo 7, imagem 1 %32
    • Tie a knot around the stick handle to secure the fishing line. (it may take several knots to secure the fishing line and you can adjust the length as needed with scissors)
    • Note: Repeat the previous steps to other parts of the puppet if necessary.
  8. Repairing Puppet Strings: passo 8, imagem 1 %32
    • This is what your puppet should look like.
    • Happy puppet-ing!
Conclusão
Equipe
Missouri Western, Team 1-4, Adkins Fall 2015 Membro de Missouri Western, Team 1-4, Adkins Fall 2015
MWSU-ADKINS-F15S1G4
Membros da 2
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 23
Duração total: 3,004
