Ir para o conteúdo principal
Repairing Polaroid Sun 600 LMS Gear Train
O que você precisa
  1. Repairing Polaroid Sun 600 LMS Gear Train, Open film door: passo 1, imagem 1 %32 Repairing Polaroid Sun 600 LMS Gear Train, Open film door: passo 1, imagem 2 %32
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Repairing Polaroid Sun 600 LMS Gear Train: passo 2, imagem 1 %32
    • Locate small silver gear in top left corner of film bay.
  3. Repairing Polaroid Sun 600 LMS Gear Train: passo 3, imagem 1 %32
    • Using a plastic opening tool, rotate gear downward until jam is cleared.
Conclusão
5 outras pessoas executaram este guia.
Matthew Lessig
Membro desde: 01/20/10
63 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-18, Maness Winter 2010 Membro de Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
Membros da 4
Autoria de 4 guias
3 comentários
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
Tiffany - Responder
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Jordan Brown -
Currently trying to fix it but after the steps it isn’t working. How do I know how many times to turn the gear?
Eleanor Murphy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 38
Duração total: 9,063
