Ir para o conteúdo principal
Repairing Oster 6344 Toaster Lever
O que você precisa
  1. Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: passo 1, imagem 1 %32 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: passo 1, imagem 2 %32 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: passo 1, imagem 3 %32
    • Assure the toaster is unplugged.
  2. Repairing Oster 6344 Toaster Lever: passo 2, imagem 1 %32 Repairing Oster 6344 Toaster Lever: passo 2, imagem 2 %32
    • Look down into the bread slots and assure that the metal tongues are not bent or crooked.
    • If the metal tongues are bent use the pliers to straighten them.
    • Plug your toaster back in and test it to see if the lever stays down.
  3. Repairing Oster 6344 Toaster Lever: passo 5, imagem 1 %32
    • (Optional): To clean the toaster, make sure it is unplugged, empty the crumb tray and then clean out all visible residue.
    • Note: Compressed air, wooden skewers, and slightly damp, lint free cloths are most helpful when cleaning your toaster.
    • Be sure that the toaster is completely dry from cleaning before you reassemble it.
Conclusão
Daniel
Membro desde: 07/13/13
109 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 1,639
