Ir para o conteúdo principal
Repairing Nokia Lumia 520 Power Button
O que você precisa
  1. Repairing Nokia Lumia 520 Power Button, Repairing Nokia Lumia 520 Power Button: passo 1, imagem 1 %32
    • Remove the back cover from the phone.
    • Take a bus ticket or anything else that has a thickness of 0.5-0.6 mm.
    • Cut the ticket to form a triangle.
    • Insert the triangle in the gap between the button and the chassis.
    • Cut the part of the ticket that is out of the chassis.
    • Now with a paper clip tests if it works.
    • If it works remount the back cover. If i doesn't work probably the problem is the button and not the contact and you need to replace it.
Conclusão
6 outras pessoas executaram este guia.
keroro90
Membro desde: 08/07/14
213 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,848
