Ir para o conteúdo principal
Repairing Nokia 6500 Slide LCD
O que você precisa
  1. Repairing Nokia 6500 Slide LCD, LCD: passo 1, imagem 1 %32 Repairing Nokia 6500 Slide LCD, LCD: passo 1, imagem 2 %32 Repairing Nokia 6500 Slide LCD, LCD: passo 1, imagem 3 %32
    • Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card.
  2. Repairing Nokia 6500 Slide LCD: passo 2, imagem 1 %32
    • Remove four screws using torx 5 screwdriver.
  3. Repairing Nokia 6500 Slide LCD: passo 3, imagem 1 %32 Repairing Nokia 6500 Slide LCD: passo 3, imagem 2 %32 Repairing Nokia 6500 Slide LCD: passo 3, imagem 3 %32
    • Pry each side evenly around its edges. The phone should start to split into two halves.
  4. Repairing Nokia 6500 Slide LCD: passo 4, imagem 1 %32 Repairing Nokia 6500 Slide LCD: passo 4, imagem 2 %32
    • The top and bottom half of the phone is still connected by two ribbon connectors each side. Use a thin plastic like a credit card to carefully disconnect it.
  5. Repairing Nokia 6500 Slide LCD: passo 5, imagem 1 %32
    • Make sure all components stay on each side (see picture).
  6. Repairing Nokia 6500 Slide LCD: passo 6, imagem 1 %32 Repairing Nokia 6500 Slide LCD: passo 6, imagem 2 %32
    • Pull the black part away from the rest of the phone in the direction shown by the white arrows follows by the blue.
    • This way you can accessing the two screws at the bottom of the phone. Remove four srews using torx 5 screwdriver.
  7. Repairing Nokia 6500 Slide LCD: passo 7, imagem 1 %32 Repairing Nokia 6500 Slide LCD: passo 7, imagem 2 %32
    • Carefully pry out the lcd cover.
    • Make sure the board connector pass the cover by angle.
  8. Repairing Nokia 6500 Slide LCD: passo 8, imagem 1 %32 Repairing Nokia 6500 Slide LCD: passo 8, imagem 2 %32 Repairing Nokia 6500 Slide LCD: passo 8, imagem 3 %32
    • Disconnect the LCD connector.
    • Carefully peel the ribbon away from the back of the screen. It's held in place with double sided tape.
    • The LCD screen will now be loose and can be removed and replace with the new one.
Conclusão
Uma outra pessoa concluiu este guia.
dwi
Membro desde: 07/02/13
163 Reputação
Autoria de 1 guia
2 comentários
Great - have screen in. Now, have you ever replaced the port / jack for the charger? Mine will not accept the prong all of a sudden
Brenda Kent - Responder
Got new charger port in 2017, now the battery goes - tried several batteries - and tried them in other phones and are fine - thinking something shorting or draining it in the phone?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 40
Duração total: 4,152
