Pular para o conteúdo principal
Introdução
Nokia 6500 Slide LCD replacement. Save your money & time. Do it for as low as IDR 50,000 and it takes less than 10 minutes.
Peças
Nenhum componente especificado.
  1. Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card. Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card. Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card.
    • Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card.
  2. Remove four screws using torx 5 screwdriver.
    • Remove four screws using torx 5 screwdriver.
  3. Pry each side evenly around its edges. The phone should start to split into two halves. Pry each side evenly around its edges. The phone should start to split into two halves. Pry each side evenly around its edges. The phone should start to split into two halves.
    • Pry each side evenly around its edges. The phone should start to split into two halves.
  4. The top and bottom half of the phone is still connected by two ribbon connectors each side. Use a thin plastic like a credit card to carefully disconnect it. The top and bottom half of the phone is still connected by two ribbon connectors each side. Use a thin plastic like a credit card to carefully disconnect it.
    • The top and bottom half of the phone is still connected by two ribbon connectors each side. Use a thin plastic like a credit card to carefully disconnect it.
  5. Make sure all components stay on each side (see picture).
    • Make sure all components stay on each side (see picture).
  6. Pull the black part away from the rest of the phone in the direction shown by the white arrows follows by the blue. This way you can accessing the two screws at the bottom of the phone. Remove four srews using torx 5 screwdriver.
    • Pull the black part away from the rest of the phone in the direction shown by the white arrows follows by the blue.
    • This way you can accessing the two screws at the bottom of the phone. Remove four srews using torx 5 screwdriver.
  7. Carefully pry out the lcd cover. Make sure the board connector pass the cover by angle.
    • Carefully pry out the lcd cover.
    • Make sure the board connector pass the cover by angle.
  8. Disconnect the LCD connector. Carefully peel the ribbon away from the back of the screen. It's held in place with double sided tape. The LCD screen will now be loose and can be removed and replace with the new one.
    • Disconnect the LCD connector.
    • Carefully peel the ribbon away from the back of the screen. It's held in place with double sided tape.
    • The LCD screen will now be loose and can be removed and replace with the new one.
Conclusão
Uma outra pessoa concluiu este guia.
dwi
Membro desde: 02-07-2013
163 reputação
Autoria de 1 guia
Great - have screen in. Now, have you ever replaced the port / jack for the charger? Mine will not accept the prong all of a sudden
Brenda Kent - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Todo: 2,819
