Ir para o conteúdo principal
Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector
O que você precisa
  1. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Battery: passo 1, imagem 1 %32
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
    Quel est le nom du vis svp je l'ai perdu et j'ai pas la référence
    la chaîne de Samarium - Responder
    Bonjour @lachainede96340 D'après les instructions du tutoriel, il s'agit d'une vis Phillips (ou cruciforme) #00 de 4 mm de long. Ces mesures devraient suffire pour trouver une vis de remplacement dans votre stock de vis ou en magasin le cas échéant.
    Claire Miesch -
  2. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector: passo 2, imagem 1 %32
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector: passo 3, imagem 1 %32
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Back Cover: passo 4, imagem 1 %32 Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector, Back Cover: passo 4, imagem 2 %32
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Repairing Nintendo Game Boy Advance SP 32-pin cartridge connector: passo 5, imagem 1 %32
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
    • Remove the back cover of your gameboy advance sp. When you have the internals exposed and the battery removed you'll need to grab some kind of narrow pointy tool like a bent safety pin or (thin) paper clip. Also make sure you have good light.
    • Look inside the cartridge connector at the metal pins. See how they're all contained within a plastic housing? Each pin has its own little square. You're going to take that safety pin and pop each pin out of its hole and towards where the game cartridge's metal contacts would sit if it were inserted.
    • Understand that doing this to the cartridge connector will make inserting and removing game cartridges quite difficult. It is doable, but it will hurt your thumbs. Alternatively, you could try bending the pins up or out without displacing them from their plastic housing. I was not able to make this work.
    • When you've completed breaking--I mean--repairing the cartridge connector, examine the pins and make sure they are all up against the outside edge of their respective plastic squares. If they're bent too far towards where the cartridge's contacts insert, the pins will get mashed when you jam the first game cart in.
    • Now put your gameboy back together and push a game cartridge in--hard. When it goes in, flip the switch on and hope for the best. Be prepared for sore thumbs when it comes time to switch cartridges. Removing them is harder than inserting.
Conclusão
6 outras pessoas executaram este guia.
denova
Membro desde: 10/06/13
349 Reputação
Autoria de 1 guia
Um comentário
My beloved Game Boy had developed a bit of a "twitch". It would reset itself at completely random moments, leaving me staring in horror at the start up screen of Pokemon Blue. I had cleaned the contacts of the Game Boy and the game cartridge several times but that wasn't helping. It was clear that the pins weren't tight enough.
I followed this guide, using a thumb tack as my tool to bend the pins down. It worked well. I experienced a momentary panic when the first pin popped out of place, thinking I had pressed too hard and damaged it but a quick look told me I was fine.
I put it back together and have played for an hour or so. The Game Boy is working wonderfully again. The pins are very tight, as the guide said they would be. Getting the game in or out requires a lot more force than it used to but not so much that it requires a bodybuilder to accomplish.
carljarms - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 165
Duração total: 19,490
