Ir para o conteúdo principal
Repairing Nintendo 64 Controller Joystick Replacement
O que você precisa
  1. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: passo 1, imagem 1 %32 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: passo 1, imagem 2 %32 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: passo 1, imagem 3 %32
    • Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
    • Remove the 2 #00 Phillips screws from the expansion slot
    • Remove the rear housing and set aside.
  2. Repairing Nintendo 64 Controller Joystick Replacement: passo 2, imagem 1 %32 Repairing Nintendo 64 Controller Joystick Replacement: passo 2, imagem 2 %32 Repairing Nintendo 64 Controller Joystick Replacement: passo 2, imagem 3 %32
    • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
    • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  3. Repairing Nintendo 64 Controller Joystick Replacement: passo 3, imagem 1 %32 Repairing Nintendo 64 Controller Joystick Replacement: passo 3, imagem 2 %32 Repairing Nintendo 64 Controller Joystick Replacement: passo 3, imagem 3 %32
    • Disconnect the joystick data cable and remove the old joystick.
    • To install your new joystick, simply follow these instructions in reverse.
Conclusão
Test out your controller! It should be feeling like new.
33 outras pessoas executaram este guia.
Zillatron
Membro desde: 08/28/12
1.511 Reputação
Autoria de 1 guia
2 comentários
If you don't line up the z button accurately it can be tricky getting the case back on.
Rainer De Temple - Responder
I have a couple thumbstick replacements that do not have the connector. They are from Sodial, and I was wondering if there was a way that they can be easily connected.
derocher1 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 45
Últimos 30 dias: 179
Duração total: 44,263
