Ir para o conteúdo principal
Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.
O que você precisa
  1. Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece., Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: passo 1, imagem 1 %32
    • Remove the foam speaker cover. Locate (4) T5 Torx screws and remove.
  2. Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: passo 2, imagem 1 %32
    • Remove (3) Phillips #000 screws.
    • Remove circuit board
  3. Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: passo 3, imagem 1 %32 Repairing Logitech H800 Wireless Headset Fix the rattling on the right ear piece.: passo 3, imagem 2 %32
    • Optional, remove media buttons section by removing (3) Phillips #000 screws.
    • Cut a circular piece of foam and stuff it under the center section.
    • You are now finished! Just reassemble
Conclusão
7 outras pessoas executaram este guia.
SYN1ST3R
Membro desde: 03/06/10
327 Reputação
Autoria de 1 guia
6 comentários
Please, can you help with silencing the low battery sound?
Houssam - Responder
OMG.. Best tutorial! I was looking at completing this and then stumbled upon your post.
The button rattle was driving me nuts!
TropiKalSTORM - Responder
Warning: this is a huge pain! I can confirm it does work though, so thank you!
Some tips:
- After removing the 4 Torx, fully extend the adjustable arm of the right earpiece/headband, it will make it easier to remove the cover
- There are very thin delicate wires connecting the PCB to the earpiece, making everything more difficult
- I could not generate enough torque with my thin stainless jewelers screwdrivers, trying as hard as I could. I recommend a large handle screwdriver. I ended up putting my jewelers screwdriver in my drill, this worked perfectly.
- I used a cut up earplug for the foam, works well, but was hard to shove into place
- Remember to put the sliding switch back into place before putting the screws in for the PCB when putting back together
Joey - Responder
Can anybody help me with the on/off (bluetooth/stick) switch? It’s the worst button ever. Function only after 5 or 6 tries. Ruining my nails every time. Is it replacable?
Peter Claassen - Responder
My kitty got a hold of my Logitech H800 and chewed on the microphone - I was wondering if there is a step on how to replace the microphone on the Logitech H800?
albwillin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 7,134
