Ir para o conteúdo principal
Repairing HTC Droid Incredible LCD
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Repairing HTC Droid Incredible LCD, Battery: passo 1, imagem 1 %32 Repairing HTC Droid Incredible LCD, Battery: passo 1, imagem 2 %32 Repairing HTC Droid Incredible LCD, Battery: passo 1, imagem 3 %32
    • Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
  2. Repairing HTC Droid Incredible LCD: passo 2, imagem 1 %32 Repairing HTC Droid Incredible LCD: passo 2, imagem 2 %32
    • Remove battery, prying from the provided gap at the upper-right corner of the battery
  3. Repairing HTC Droid Incredible LCD, Back Panel: passo 3, imagem 1 %32 Repairing HTC Droid Incredible LCD, Back Panel: passo 3, imagem 2 %32
    • Depress MicroSD to eject it from the side of the case.
  4. Repairing HTC Droid Incredible LCD: passo 4, imagem 1 %32 Repairing HTC Droid Incredible LCD: passo 4, imagem 2 %32 Repairing HTC Droid Incredible LCD: passo 4, imagem 3 %32
    • Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
  5. Repairing HTC Droid Incredible LCD: passo 5, imagem 1 %32 Repairing HTC Droid Incredible LCD: passo 5, imagem 2 %32 Repairing HTC Droid Incredible LCD: passo 5, imagem 3 %32
    • Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures.
    • Start at the top, and work clockwise, being careful not to break the clips.
    • There are, 1, 3, 2, and 3 clips on each side, respectively.
    • After the clips are disengaged, there are no cables holding the back panel in place.
  6. Repairing HTC Droid Incredible LCD, Optical Track Pad: passo 6, imagem 1 %32 Repairing HTC Droid Incredible LCD, Optical Track Pad: passo 6, imagem 2 %32 Repairing HTC Droid Incredible LCD, Optical Track Pad: passo 6, imagem 3 %32
    • Use your spudger to release the jaw clip holding the Optical Track Pad cable to the logic board.
    • Remove Optical Track Pad from logic board.
  7. Repairing HTC Droid Incredible LCD, Logic Board: passo 7, imagem 1 %32
    • Use your spudger to release the remaining clips, disconnecting the ribbon cables from the logic board.
  8. Repairing HTC Droid Incredible LCD: passo 8, imagem 1 %32 Repairing HTC Droid Incredible LCD: passo 8, imagem 2 %32
    • Remove 2 Phillips Screws holding the logic board to the front panel.
    • Gently lift the logic board off the front panel.
  9. Repairing HTC Droid Incredible LCD, LCD: passo 9, imagem 1 %32 Repairing HTC Droid Incredible LCD, LCD: passo 9, imagem 2 %32
    • Remove the two phillips screws from the top of the LCD frame.
    • Use your spudger to pry the LCD out of the frame.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 3,692
