Ir para o conteúdo principal
Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip
O que você precisa
  1. Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip, Repairing Gillette Mach 3 Disposable Razor Blade lubricated strip: passo 1, imagem 1 %32
    • Cut away the old (likely disintegrated) strip from the blade using a knife. Get a waterproof bandaid and cut 4 or 5 thin strips from the sticky part and layer them to make a new strip. Use the smooth-type bandage; not flexible fabric. Then sharpen by stropping on blue jeans. Voila! Shaves just like new. Blow dry after shaving to prevent rust.
Conclusão
4 outras pessoas executaram este guia.
PartsIn
Membro desde: 12/31/12
247 Reputação
Autoria de 1 guia
4 comentários
This is great! I'll have to try it. I'd love more information on how to sharpen the blades on blue jeans. How much stroking does it take to sharpen them? How do you tell when it's sharp enough?
Kyle Wiens - Responder
Hey it takes about 15 to 20 strokes each way ( up and down) to maintain it. And 150 to 200 each way to re sharpen it. And when you can take off most of the hair on your arm in one pass its sharp enough
chase morris -
Yeah, a guide on "stopping" a razor would be great!
Daniel Beardsley - Responder
Hi, I have a sterling silver razor handle with. Gillette blade housing. The housing is worn and does no longer supports the blade. Can I get a replacement top and switch it out with the broken one? Thanks Kevin
Kevin Locke - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 30
Duração total: 11,299
