Introdução
I have already sent my Sigma lens for the replacement of the focus ring before. So when the new ring broke after 1 more year of usage I decided not to waste money any more and to try to fix it by myself.
O que você precisa
Put the lens on the table the way you can access the buttom screws.
Unscrew the black screws near the contact plate and from the black inner ring (which stands between the optical lens and the top outer ring).
Now you should be extra aware and do the next operation very carefully!
Remove the inner optical part from the outer body part of the lens.
Try to memorize the way the parts were inserted one into another (when assembilng the lens I have lost a lot of time figuring out how the optical part should be fitted into the outer body part).
Put the optical part away very carefully without putting it upside down.
DO NOT TRY TO DISASSAMBLE THE OPTICAL PART.
9 outras pessoas executaram este guia.
6 comentários
I dismounted the lens to make the repair and unintentionally I DISASSAMBLE THE OPTICAL PART and now I can not ride back. chaos
Video da sökme ve takma kısımları var.
I am very thankful to You, as just repaired my Sigma by this method.
Thank You very much!
I have a Sigma DG 70-300 zoom. Problem: zoom part comes all the way out and will not go back in and lock in place . Can it be fixed? John polley
