Introdução
Stalled printer for error 0xF2 or 0xF3
This error happens when there are some problems with the encoder when the roller tries to move paper.
O que você precisa
Remove the paper tray
Remove the paper cassette
Remove the ink tanks.
Clean the right encoder very gently with a dry tissue or a soft brush.
16 outras pessoas executaram este guia.
14 comentários
Perfect. I used this guide to disassemble my printer.
I had 0xF1 and/or 0xF4. The reason was some paper stuck between the gears of the paper feed (in this guide step 12).
I hope this hint will help others. I didn't find any info about these error code online.
Error descriptions I found here - http://www.fatalerrors.info/
muito obrigado pela ajuda
