Ir para o conteúdo principal
Repairing Display
O que você precisa
  1. Repairing Display, Display: passo 1, imagem 1 %32
    • Remove the 6 outer screws on the underside of the laptop.
    • Open the battery compartment and remove the 7 visible screws.
    • Pry the corners of the bezel at the base of the keyboard, pushing up until it loosens.
    • Carefully remove the ribbon connections of the keyboard, power button, and wifi button.
    • Disconnect and re-connect the white monitor ribbon located on the left side to make sure it sits firmly in the connection.
    • Reassemble the laptop by following these steps in reverse.
    • The monitor should work when powered on again.
Conclusão
9 outras pessoas executaram este guia.
duncan
Membro desde: 06/28/12
238 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 12,126
