Ir para o conteúdo principal
Repairing Canon PowerShot Lens Error E-18
O que você precisa
  1. Repairing Canon PowerShot Lens Error E-18, Repairing Canon PowerShot Lens Error E-18: passo 1, imagem 1 %32
    • Place camera lens facing upwards on the table.
    • Press and hold down the power button.
    • Simultaneously press down the shutter button.
  2. Repairing Canon PowerShot Lens Error E-18: passo 2, imagem 1 %32
    • Replace the batteries in the camera.
    • To open the battery cover slide the black lever on the underside of the camera and pull the cover toward the front.
    • Remove the old batteries from the camera and wait a few moments.
    • Put in a fresh set of batteries.
    • Close battery slide and power camera back on.
  3. Repairing Canon PowerShot Lens Error E-18: passo 3, imagem 1 %32
    • Put blow dryer in the "no heat" setting prior to plugging it in.
    • Plug in and turn the blow dryer on.
    • Blow air in the gaps between the lens.
Conclusão
In conclusion, using this guide to fix the E-18 on the lens of the Canon PowerShot A80,will allow the camera to capture photos once again. To reassemble your device, follow these instructions in reverse order.
Tim
Membro desde: 01/06/11
172 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-31, Regan Winter 2011 Membro de Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Membros
Autoria de 12 guias
1Comentário do guia
merci! mon appareil fonctionne à nouveau
nadia.labadi - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 54
Ao todo: 7,733
