Ir para o conteúdo principal
Repairing Black and Decker BL3000S Power Cord
O que você precisa
  1. Repairing Black and Decker BL3000S Power Cord, Blender Base: passo 1, imagem 1 %32 Repairing Black and Decker BL3000S Power Cord, Blender Base: passo 1, imagem 2 %32
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Repairing Black and Decker BL3000S Power Cord: passo 2, imagem 1 %32
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Repairing Black and Decker BL3000S Power Cord: passo 3, imagem 1 %32 Repairing Black and Decker BL3000S Power Cord: passo 3, imagem 2 %32
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Repairing Black and Decker BL3000S Power Cord: passo 4, imagem 1 %32
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Repairing Black and Decker BL3000S Power Cord: passo 5, imagem 1 %32
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Repairing Black and Decker BL3000S Power Cord, Power Cord: passo 6, imagem 1 %32
    • Tug on wires in the marked locations to make sure they are secure.
    • If the wire stays still, the connection is secure.
    • If you still have problems with the blender, it is probably a problem with the motor. Since the motor is irreplaceable, you will have to order a new blender.
  7. Repairing Black and Decker BL3000S Power Cord: passo 7, imagem 1 %32
    • If the wire comes off, the connection is insecure. You will need to solder the connection to make it solid again.
    • If you don't know how to solder, here is a link to show you how. http://www.aaroncake.net/electronics/sol...
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 6-34, Regan Fall 2012 Membro de Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 27
Duração total: 3,856
