Ir para o conteúdo principal
Repairing Alarm Clock Clock Projector
O que você precisa
  1. Repairing Alarm Clock Clock Projector, The issue: passo 1, imagem 1 %32
    • The Problem: here I should read 12:47
  2. Repairing Alarm Clock Clock Projector: passo 2, imagem 1 %32 Repairing Alarm Clock Clock Projector: passo 2, imagem 2 %32
    • After removing the 2 screws on the bottom, carefully open the bottom frame, see location of the plastic snaps snaps
  3. Repairing Alarm Clock Clock Projector: passo 3, imagem 1 %32 Repairing Alarm Clock Clock Projector: passo 3, imagem 2 %32 Repairing Alarm Clock Clock Projector: passo 3, imagem 3 %32
    • Removes the back panel, taking care of the other plastic snaps
    • The projector and its optics is shown in the blue square
  4. Repairing Alarm Clock Clock Projector, The optics: passo 4, imagem 1 %32 Repairing Alarm Clock Clock Projector, The optics: passo 4, imagem 2 %32 Repairing Alarm Clock Clock Projector, The optics: passo 4, imagem 3 %32
    • cables are tied together with a simple ribbon, in general the inner construction seems very cheap
    • The Projector is made of three parts:
    • A red LED
    • The display with its controller
    • the lens with focus mechanics
    • All parts are kept by tiny screws that you have to remove
    • Take extra caution when handling the display, the flat cable is very weak and can be damaged by improper handling
  5. Repairing Alarm Clock Clock Projector: passo 5, imagem 1 %32 Repairing Alarm Clock Clock Projector: passo 5, imagem 2 %32 Repairing Alarm Clock Clock Projector: passo 5, imagem 3 %32
    • Carefully remove display from its supporting frame
    • The issue should be ralated to flat cable connecting display to controller
  6. Repairing Alarm Clock Clock Projector: passo 6, imagem 1 %32 Repairing Alarm Clock Clock Projector: passo 6, imagem 2 %32 Repairing Alarm Clock Clock Projector: passo 6, imagem 3 %32
    • Verify that moving the flat the display returns to work
    • put a stiffner on controller side and close to the display
    • if everything is working, reassemble the clock by doing the steps in reverse order
  7. Repairing Alarm Clock Clock Projector: passo 7, imagem 1 %32
    • Problem solved.
Conclusão
6 outras pessoas executaram este guia.
Andrea Gangemi
Membro desde: 04/26/15
172 Reputação
Autoria de 1 guia
6Comentários do guia
The clock projection displays only partial numbers.one number is missing. The face on the clock displays perfect. It's just The projection on the wall that's missing a digit
eacoch - Responder Compartilhar
my Peakeep clock keeps the correct time but you can't see the time clearly. It's as if the light is turned off.
serena williams - Responder Compartilhar
Thank you for this post! It was the exact starting point to fix my projection clock which was looking dull and had lost a few segments. While the addition of supporting tape helped for a short period, doing it again in conjunction with Step 6 of the following link (http://www.instructables.com/id/How-to-r...) - Applying heat - to the ribbon contact points was the ticket that restored my projection clock functionality.
Adam - Responder Compartilhar
Hi Adam, glad to helped you
Andrea Gangemi - Compartilhar
The display on my clock is missing parts of a number but project correct time , help ?
mandzb87 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 35
Últimos 30 dias: 126
Ao todo: 14,832
