Ir para o conteúdo principal
Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons
O que você precisa
  1. Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons, Opening the Device: passo 1, imagem 1 %32
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
    • Unscrew Circuit board attached to the top of the case with the one screw in the center. Be careful not to strip the screw/break the circuit board.
  2. Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons: passo 5, imagem 1 %32
    • Make sure all of the buttons are move-able.
    • Press buttons on circuit board while listening for a click.
    • If everything works on the inside, that might mean you need a new circuit board.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Duração total: 707
