Ir para o conteúdo principal
Introdução
Very often problem with this model. In 60% it can be resolved only with reconnecting the Touchscreen flex / ribbon cable.
If this solution not helped you then you must to change your Touchscreen.
Acer Iconia B1-A71 Touchscreen Replacement
Please SUBSCRIBE to my channel ツ
Peças
Nenhum componente especificado.
Vídeo de Apresentação
  1. Because I can't switch-off the tablet, I'm using the reset button to do this. Now, remove the back cover. If you have a memory card inside, don't forget to remove it!
    • Because I can't switch-off the tablet, I'm using the reset button to do this.
    • Now, remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Open the touchscreen flex cable connector and reconnect the cable. . Did you do it successfully?
Conclusão
15 outras pessoas concluíram este guia.
ZFix
Membro desde: 09/12/2013
178.781 Reputação
315 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
297 Membros
983 Guias de autoria
Thanks.. it worked for my tab... Great...
pandawa - Responder
s'il vous plait vous pouvez m'aider j'ai un problème avec mon Acer B1. problème de démarrage qu'on j'allume il y'a juste Acer qui s'affiche j'ai essayer d'aller en mode recovery (SD IMAGE UPDATE MODE) mais une fois que je clique dessus ça se bloque s'il vous plait besoin de votre aide
omy - Responder
If you have a memory card inside, remove it. If you have same problem again, you have a problem with Android OS or a hardware problem.
ZFix -
Great i thought i cannot use my acer anymore, but know its worked thx for the solutions.
Andri Sagita - Responder
Thanks for the info. I fixed my tablet before by using the steps. But, I had the same problem again. I tried to fix it again but it's not wrking. So how to fix the problem with Android OS or hardware problem? Cheers.
rinayaya - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 38,700
