Ir para o conteúdo principal
Repairing A Torn Skirt Ruffle
O que você precisa
  1. Repairing A Torn Skirt Ruffle, Repairing A Torn Skirt Ruffle: passo 1, imagem 1 %32
    • Fold the skirt so the ripped part is facing inside and is not visible from the outside.
  2. Repairing A Torn Skirt Ruffle: passo 2, imagem 1 %32 Repairing A Torn Skirt Ruffle: passo 2, imagem 2 %32 Repairing A Torn Skirt Ruffle: passo 2, imagem 3 %32
    • Pin the folded fabric in place, using sewing pins to secure the fabric.
    • Be careful not to pin any extra fabric from the rest of the skirt.
  3. Repairing A Torn Skirt Ruffle: passo 3, imagem 1 %32
    • Match a thread to the fabric.
  4. Repairing A Torn Skirt Ruffle: passo 4, imagem 1 %32
    • Thread your sewing needle, holding your needle straight up and pushing the thread through.
  5. Repairing A Torn Skirt Ruffle: passo 5, imagem 1 %32 Repairing A Torn Skirt Ruffle: passo 5, imagem 2 %32 Repairing A Torn Skirt Ruffle: passo 5, imagem 3 %32
    • Cut the thread to the desired length.
    • It is better to have thread that is too long rather than too short.
    • Tie a knot at the end of the cut thread to secure your stitches.
  6. Repairing A Torn Skirt Ruffle: passo 6, imagem 1 %32 Repairing A Torn Skirt Ruffle: passo 6, imagem 2 %32 Repairing A Torn Skirt Ruffle: passo 6, imagem 3 %32
    • Push your needle in one side of fabric and draw it out on other side to make the first stitch.
  7. Repairing A Torn Skirt Ruffle: passo 7, imagem 1 %32 Repairing A Torn Skirt Ruffle: passo 7, imagem 2 %32
    • Continue sewing in a straight line as demonstrated in Step 7.
    • Remove sewing pins as you go.
  8. Repairing A Torn Skirt Ruffle: passo 8, imagem 1 %32 Repairing A Torn Skirt Ruffle: passo 8, imagem 2 %32
    • When you reach the end of your thread, tie your thread in a knot in order to secure the stitches.
    • Tie your knot as close to the fabric as possible to keep the stitches tight.
  9. Repairing A Torn Skirt Ruffle: passo 9, imagem 1 %32 Repairing A Torn Skirt Ruffle: passo 9, imagem 2 %32
    • Cut off the excess thread.
    • Enjoy your fixed skirt!
Conclusão
Mariam Khan
Membro desde: 09/27/24
169 Reputação
Autoria de 1 guia
Equipe
CSU Sacramento, Team 1-13, Laflen Fall 2024 Membro de CSU Sacramento, Team 1-13, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G13
1 Membro
1 Guia de autoria
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 36
