Ir para o conteúdo principal
Repair Loose Floorboard Carpet in Vehicle
O que você precisa
  1. Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: passo 1, imagem 1 %32 Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: passo 1, imagem 2 %32
    • Pull back detached carpet from the floorboard to determine how much carpet is detached.
    Pergunte ao FixBot
    Comentar
  2. Repair Loose Floorboard Carpet in Vehicle: passo 2, imagem 1 %32 Repair Loose Floorboard Carpet in Vehicle: passo 2, imagem 2 %32
    • Apply a generous layer of spray adhesive to floorboard.
    • Wear a mask to prevent inhalation of fumes.
    • Wear gloves to prevent the adhesive from sticking to your hands.
    • Perform repair in a well ventilated area.
    Pergunte ao FixBot
    Comentar
  3. Repair Loose Floorboard Carpet in Vehicle: passo 3, imagem 1 %32
    • Allow 15-30 seconds for adhesive to dry before attaching carpet to floorboard.
    Pergunte ao FixBot
    Comentar
  4. Repair Loose Floorboard Carpet in Vehicle: passo 4, imagem 1 %32 Repair Loose Floorboard Carpet in Vehicle: passo 4, imagem 2 %32
    • Apply carpet to floorboard firmly using hands.
    • This step needs to be repeated until carpet is in place with no wrinkles or bulges.
    Pergunte ao FixBot
    Comentar
  5. Repair Loose Floorboard Carpet in Vehicle: passo 5, imagem 1 %32 Repair Loose Floorboard Carpet in Vehicle: passo 5, imagem 2 %32
    • Use a plastic squeegee to tuck the corner of the carpet into the paneling of the floorboard.
    Pergunte ao FixBot
    Comentar
  6. Repair Loose Floorboard Carpet in Vehicle: passo 6, imagem 1 %32
    • Vacuum floorboard to remove any debris or dirt.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 177
Ao todo: 10,413
