Ir para o conteúdo principal
Repair For MacBook Pro A1989 That Won't Turn On
Vídeo de Apresentação
  1. Repair For MacBook Pro A1989 That Won't Turn On, Repair For MacBook Pro A1989 That Won't Turn On: passo 1, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On, Repair For MacBook Pro A1989 That Won't Turn On: passo 1, imagem 2 %32
    • Press the power button. The MacBook won’t turn on.
    • Plug in the BY-3200 power cable and the input voltage is 20V.
    • The current reading on the DC Power Supply stays at 0.047A.
  2. Repair For MacBook Pro A1989 That Won't Turn On: passo 2, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 2, imagem 2 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 2, imagem 3 %32
    • Unplug the power cable. Next, we need to disassemble the MacBook and test.
    • The MacBook model is A1989.
    • Remove the screws and disconnect the battery connector flex cable.
  3. Repair For MacBook Pro A1989 That Won't Turn On: passo 3, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 3, imagem 2 %32
    • Plug in the BY-3200 and the input voltage is 5V.
    • The current reading on the DC Power Supply stays at 0.059A.
    • The power supply of the motherboard is only 5V, which is abnormal.
    • The normal power supply should be 20V. It indicates that the motherboard has malfunctioned.
  4. Repair For MacBook Pro A1989 That Won't Turn On: passo 4, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 4, imagem 2 %32
    • Then we remove the motherboard and install the power connector flex cable.
  5. Repair For MacBook Pro A1989 That Won't Turn On: passo 5, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 5, imagem 2 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 5, imagem 3 %32
    • The motherboard number is 820-00850-07.
    • Open the schematic diagram and bitmap.
    • U3900 is the T2 chip. U7800 is the power chip.
  6. Repair For MacBook Pro A1989 That Won't Turn On: passo 6, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 6, imagem 2 %32
    • Measure the standby voltage of the T2 chip, which is supplied by the U7800. Find U7800 on the schematic diagram.
    • This table shows the standby voltage of T2 chip.
  7. Repair For MacBook Pro A1989 That Won't Turn On: passo 7, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 7, imagem 2 %32
    • Pug in the power cable.
    • The motherboard current stops at 0.06A and the input voltage is only 5V.
  8. Repair For MacBook Pro A1989 That Won't Turn On: passo 8, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 8, imagem 2 %32
    • Measure the power supply of the motherboard.
    • The measured voltage values are normal. It can be judged that the power supply circuit of the motherboard is good.
    • Next, we need to decide if the fault (voltage failing to increase) is caused by T2 chip data problems.
  9. Repair For MacBook Pro A1989 That Won't Turn On: passo 9, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 9, imagem 2 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 9, imagem 3 %32
    • Find T2 chip on the bitmap and the location name is U3900. Search U3900 on the diagram and find the ROM chip for T2.
    • Copy signal SPI_SOCROM_MISO. Find SoC ROM and the location name is U4770. Find U4770 on bitmap.
  10. Repair For MacBook Pro A1989 That Won't Turn On: passo 10, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 10, imagem 2 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 10, imagem 3 %32
    • Find SoC ROM (U4770) on the motherboard. Remove SoC ROM chip with Hot Air Gun at 430℃.
    • Get the BY-T200 and write the new SoC ROM data. Attach the chip to the seat of BY-T200. Pin 1 of the chip must align with the red dot on the tool.
    • Then connect BY-T200 with the computer.
  11. Repair For MacBook Pro A1989 That Won't Turn On: passo 11, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 11, imagem 2 %32
    • Install the driver and open AsProgrammer.
  12. Repair For MacBook Pro A1989 That Won't Turn On: passo 12, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 12, imagem 2 %32
    • Click Read ID and select MX25U3235F_1.8V.
  13. Repair For MacBook Pro A1989 That Won't Turn On: passo 13, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 13, imagem 2 %32
    • Click Open file and select A1989 T2 ROM original data.bin.
  14. Repair For MacBook Pro A1989 That Won't Turn On: passo 14, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 14, imagem 2 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 14, imagem 3 %32
    • Click Auto Program and click Yes.
    • Data writing has completed.
  15. Repair For MacBook Pro A1989 That Won't Turn On: passo 15, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 15, imagem 2 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 15, imagem 3 %32
    • Unplug BY-T200. Solder the chip back to the motherboard.
    • Plug in the power cable. The BY-3200 shows an increase in input voltage from 5V to 20V.
    • The current jump on the DC power supply is normal, which indicates that the motherboard is turned on.
  16. Repair For MacBook Pro A1989 That Won't Turn On: passo 16, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 16, imagem 2 %32
    • Disconnect the power cable and install the motherboard. Plug in the power cable.
    • The MacBook is turned on and can enter the system.
  17. Repair For MacBook Pro A1989 That Won't Turn On: passo 17, imagem 1 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 17, imagem 2 %32 Repair For MacBook Pro A1989 That Won't Turn On: passo 17, imagem 3 %32
    • Lastly, assemeble the MacBook.
    • Connect the battery flex cable and put the back cover on.
    • Plug in the power cable and press the power button. The MacBook is turned on and can enter the system. The fault has been cleared.
Conclusão
In the first place, we used MacBook BY-3200 power cable to observe the change of boot voltage and current. The voltage values related to the boot circuit on the motherboard were found to be normal after measuring. To determine whether the fault was caused by data problems, BY-T200 Data Assistant was used to read and write the data of T2 chip ROM. After rewriting the ROM data of T2 chip, the MacBook could turn on and enter the system. The no power fault has been cleared.
REWA
Membro desde: 11/24/20
18.432 Reputação
Autoria de 55 guias
3Comentários do guia
Whre can I buy T2 rom original file ?
muradyangrigor - Responder
I have chunky fingers for female & not as strong as I use to be, will try. That iMac was hard enough as it was!
ladycerridwyn - Responder
Where can we find this "A1989 T2 ROM original data.bin"?
Lonny Gallant - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 56
Últimos 30 dias: 240
Ao todo: 10,057
