Ir para o conteúdo principal
Desktop PC Hard Drive Replacement
O que você precisa
  1. Desktop PC Hard Drive Replacement, Left Panel: passo 1, imagem 1 %32
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Hard Drive Replacement: passo 2, imagem 1 %32 Desktop PC Hard Drive Replacement: passo 2, imagem 2 %32
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Hard Drive Replacement, Right Panel: passo 3, imagem 1 %32
    • Remove two Phillips #2 head 5mm screws from the back side of the computer case.
  4. Desktop PC Hard Drive Replacement: passo 4, imagem 1 %32 Desktop PC Hard Drive Replacement: passo 4, imagem 2 %32
  5. Desktop PC Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Remove two Phillips #2 head 5mm screws holding the hard drive in place.
  6. Desktop PC Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove two Phillips #2 head 5mm screws holding in the other side of the hard drive.
  7. Desktop PC Hard Drive Replacement: passo 7, imagem 1 %32
    • Slide the hard drive out from the metal casing.
  8. Desktop PC Hard Drive Replacement: passo 8, imagem 1 %32
    • Remove the cables from the back of the hard drive.
Conclusão
59 outras pessoas executaram este guia.
Rubin Girling
Membro desde: 04/14/15
712 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-5, Maness Spring 2015 Membro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
Membros da 4
Autoria de 45 guias
2 comentários
Footnote: the processing of removing a drive from your system may vary slightly depending on the manufacturer of your system, or if you built it yourself; the manufacturer of the case.
Jack G - Responder
Pour remonter l'installation,
-remonter le disque dur faite le glisser dans la cage métallique
- fixer le disque dur avec les vis retirées
-fixer les câbles à l'arrière du disque( câble d'alimentation et nappe de données)
-mettre les panneaux dans l'ordre du retrait
- procéder à l'installation du système d'exploitation...
Rufin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 105
Duração total: 8,734
