Introdução
In this guide, you will be shown step-by-step how to replace your Le Pan II motherboard. The fans should remain attached to the motherboard when you are finished.
O que você precisa
Insert metal spudger between front and back panel to pry apart.
Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
Use the plastic opening tool to push out the wires connecting the battery to the motherboard and put battery aside.
Use the Plillips 00 screwdriver head to unscrew the screws to the motherboard.
