Esta tradução pode não refletir as atualizações mais recentes do guia de fontes. Ajude a atualizar a tradução ou veja guia de fontes.
Introdução
Vous pouvez installer des disques durs d'une épaisseur maximale de 9,5 mm.
O que você precisa
À l'aide d'une pièce de monnaie, faites tourner la vis de verrouillage de la batterie de 90 degrés dans le sens des aiguilles d'une montre.
Dévissez les trois vis Phillips espacées régulièrement sur la paroi arrière du compartiment de la batterie.
Saisissez la languette en plastique blanc fixée au disque dur et tirez-la vers la droite pour retirer le disque dur de l'ordinateur.
Retirez les deux vis Torx T8 noires qui fixent le support argenté au disque dur.
Retirez le support en métal argenté du disque dur.
Si vous installez un nouveau disque dur, nous avons un tutoriel d'installation OS X.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
867 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
85%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
30 comentários
This upgrade is so easy. Just do it. Even your dad could do this.
After the upgrade to a 320 GB 7200 rpm, the MacBook (1.83 GHz Intel Core Duo A1181, with 2 GB of ram) works like a new computer. However, the fan comes on so easy - and stays on forever. Is this due to the increased speed of the hard drive? Is there a way to turn down the hard drive speed when used on AC power?
The rubber guide came off on mine too. The mistake is that the screws without the flanges go on the outside edge of the Mac and the flange ones towards the inside. If you do it backwards it will pull the rubber guide off and then an otherwise effortless install will take a while longer to complete.
it's really easy to do this - there's no need to pay someone else! thanks for this awesome tutorial.
Very simple and easy! The biggest challenge was the walk to Radio Shack in cold weather to go get a !#!@ torx! The OSX installation guide was also a big help.
Bought a Crucial M4 CT128M4SSD2 (128 GB SSD), removal was quick and easy. This was my wife's mac, I personally do not own Apple products. My challenge was that I had to erase the drive (which in the process re-formats the ssd) which got the install up and running.
