Introdução
Remplacement du SSD m.2 interne d'un Dell Latitude E7470. Il vous sera nécessaire de choisir un SSD m.2 2280 uniquement, les autres tailles ne sont pas compatibles avec ce PC.
O que você precisa
Pour commencer, avec le tournevis Philips #0 retirez les 8 vis entourées en rouge sur la photo ci-contre.
Puis à l'aide du iFixit Opening Picks, soulevez depuis le connecteur docks. Déclipsez-le doucement.
Après avoir retiré le capot, l'emplacement du SSD est en bas à droite, juste à côté de la batterie.
Pour retirer le SSD, il suffit de retirer l'unique vis qui le retient. Vous pouvez alors tirer le SSD hors de son emplacement.
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
5 outras pessoas executaram este guia.
8 comentários
It does! It has only one plastic piece (I forgot what the proper term is), not 2.
It’s not working for me with Kingston nvme NV1
If no ram or ssd do ya got to put windows 10 back on I got no recover usb .or a dell recovery usb with 10 or what was original on it .its a e7470
Without RAM you cannot start the computer, it is an essential component.
Without SSD you have no storage so you can't install Windows.
Hyperion -
Is it possible to install two SSD on this Dell Latitude e7470 laptop? I am currently eyeing one and would like to know if to purchase an extra SSD for it.
Thanks in advance.
No extra slot for a extra ssd card. But you can insert High capacity SD card into the Card Slot to give you more disk memory.!
Dumb question maybe - how do you get the cover back on? The front specifically doesn't seem to line up with anything on the main chassis.
It's a good idea to disconnect the Battery before removing any components. This is the pull tab to the left of the NAND SSD and above the battery
Richard Holmes - Responder
