Introdução
This guide will instruct you on how to remove the fan blade and transformer.
Ferramentas
Peças
Não são necessárias peças.
Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
In order to remove the fan blade pliers were used to remove the holding nut.
After the holding nut is loose, use the pliers to pull up to remove the nut.
Quase terminado!
Conclusão
