Ir para o conteúdo principal
Removing the Samsung LA40R81BD 40in LCD TV Power Supply Board
O que você precisa
  1. Removing the Samsung LA40R81BD 40in LCD TV Power Supply Board, Rear Cover: passo 1, imagem 1 %32
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
  2. Removing the Samsung LA40R81BD 40in LCD TV Power Supply Board, Power Supply Board: passo 2, imagem 1 %32
    • Remove the 7 connectors from the board
    • Remove the 7 screws from the board
    • Lift the main board away from the chassis ensuring you don's snag or catch any of the cables.
Conclusão
16 outras pessoas executaram este guia.
Richdave
Membro desde: 04/09/10
32.051 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.521 guias
2 comentários
Ma télé LCD Samsung ne veule pas s allume pas de courant que dois je faire s.v.p
Samir Chaaraoui - Responder
Vielen Dank für Ihren Artikel. Das Ausstecken ist für mich jetzt einfacher geworden! Ich hoffe, Sie können eine Anleitung zum Entfernen des Netzteils mit dem incredibox-Gerät geben.
Lily Collins - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 39
Duração total: 7,557
