Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Provides detail on removing the modem card from the laptop
O que você precisa
Flip laptop over and locate the battery release button
Push release button to the left to release battery and gently pull battery from the laptop
Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
Slide the retention clips toward the keyboard to release the keyboard
Locate the modem card and remove the 2 M2.5×4.0 screws
The modem card is it is plugged into a connector on the logic board. Gently lift the card up and out of the laptop
Disconnect the cable from the modem card to complete removal
Uma outra pessoa concluiu este guia.
