Ir para o conteúdo principal
Removing the HP Elitebook 6930p modem card
O que você precisa
  1. Removing the HP Elitebook 6930p modem card, Battery Removal: passo 1, imagem 1 %32 Removing the HP Elitebook 6930p modem card, Battery Removal: passo 1, imagem 2 %32 Removing the HP Elitebook 6930p modem card, Battery Removal: passo 1, imagem 3 %32
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p modem card, Keyboard: passo 2, imagem 1 %32 Removing the HP Elitebook 6930p modem card, Keyboard: passo 2, imagem 2 %32 Removing the HP Elitebook 6930p modem card, Keyboard: passo 2, imagem 3 %32
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p modem card: passo 3, imagem 1 %32 Removing the HP Elitebook 6930p modem card: passo 3, imagem 2 %32 Removing the HP Elitebook 6930p modem card: passo 3, imagem 3 %32
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p modem card: passo 4, imagem 1 %32 Removing the HP Elitebook 6930p modem card: passo 4, imagem 2 %32 Removing the HP Elitebook 6930p modem card: passo 4, imagem 3 %32
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p modem card, Modem card: passo 5, imagem 1 %32 Removing the HP Elitebook 6930p modem card, Modem card: passo 5, imagem 2 %32
    • Locate the modem card and remove the 2 M2.5×4.0 screws
    • The modem card is it is plugged into a connector on the logic board. Gently lift the card up and out of the laptop
    • A plastic spudger may be useful in lifting the card out
    • Be careful as there is a small cable connected to the edge of the modem card closest to the LCD display
    • Disconnect the cable from the modem card to complete removal
Conclusão
Uma outra pessoa concluiu este guia.
Richdave
Membro desde: 04/09/10
32.063 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.529 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,385
