Ir para o conteúdo principal
Removing the HP Elitebook 6930p Switch Cover
O que você precisa
  1. Removing the HP Elitebook 6930p Switch Cover, Battery Removal: passo 1, imagem 1 %32 Removing the HP Elitebook 6930p Switch Cover, Battery Removal: passo 1, imagem 2 %32 Removing the HP Elitebook 6930p Switch Cover, Battery Removal: passo 1, imagem 3 %32
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Switch Cover, Keyboard: passo 2, imagem 1 %32 Removing the HP Elitebook 6930p Switch Cover, Keyboard: passo 2, imagem 2 %32 Removing the HP Elitebook 6930p Switch Cover, Keyboard: passo 2, imagem 3 %32
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Switch Cover: passo 3, imagem 1 %32 Removing the HP Elitebook 6930p Switch Cover: passo 3, imagem 2 %32 Removing the HP Elitebook 6930p Switch Cover: passo 3, imagem 3 %32
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p Switch Cover: passo 4, imagem 1 %32 Removing the HP Elitebook 6930p Switch Cover: passo 4, imagem 2 %32 Removing the HP Elitebook 6930p Switch Cover: passo 4, imagem 3 %32
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p Switch Cover, Switch Cover: passo 5, imagem 1 %32 Removing the HP Elitebook 6930p Switch Cover, Switch Cover: passo 5, imagem 2 %32 Removing the HP Elitebook 6930p Switch Cover, Switch Cover: passo 5, imagem 3 %32
    • Remove the two M2.0×4.0 broad-head screws.
    • Remove the three Torx T8 M2.5×7.0 screws.
  6. Removing the HP Elitebook 6930p Switch Cover: passo 6, imagem 1 %32 Removing the HP Elitebook 6930p Switch Cover: passo 6, imagem 2 %32 Removing the HP Elitebook 6930p Switch Cover: passo 6, imagem 3 %32
    • Turn the computer over with the front toward you and the open the computer as far as possible.
    • Release the ZIF connector for the power button board cable.
    • Remove the switch cover by lifting it straight up and flip it forward.
    • Release the ZIF connector for the LED board cable.
Conclusão
4 outras pessoas executaram este guia.
Richdave
Membro desde: 04/09/10
32.063 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 1,946
