Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will show you how to locate and remove the RTC (CMOS) battery from the laptop. Please note: Removal of this battery will not clear a BIOS password on the HP Elitebook 6930P and some HP Business Class notebooks.
Peças
Nenhum componente especificado.
  1. Flip laptop over and locate the battery release button Push release button to the left to release battery and gently pull battery from the laptop Push release button to the left to release battery and gently pull battery from the laptop
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard Slide the retention clips toward the keyboard to release the keyboard
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Kit de pontas universal para chave
    112 bits for every fix.
    Upgrade Your Toolbox
  4. Use a plastic pry tool to lift the rear edge of the keyboard. Pull  the keyboard slightly towards the display to disengage  the tabs along the front of the keyboard from the laptop palm rest. Lift the keyboard up to reveal the ribbon connectors
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  5. Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable Release the smaller ribbon cable by lifting up the white retainer I found it easier to reinstall both cables with the new keyboard resting on the back edge
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  6. Locate the the battery If the battery wires are running underneath the WLAN module you will have to remove it first.  In my case it was necessary to remove the WLAN module.
    • Locate the the battery
    • If the battery wires are running underneath the WLAN module you will have to remove it first. In my case it was necessary to remove the WLAN module.
    • Disconnect the battery from the connector
    • Removal of this battery will not clear a BIOS password on the HP Elitebook 6930P and some other Business Class notebooks.
    • Gently un-clip the battery from the plastic housing to completely remove it from the laptop
Conclusão
9 outras pessoas concluíram este guia.
Richdave
Membro desde: 09-04-2010
30.182 Reputação
30 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
293 Membros
929 Guias de autoria
This did not work for me. I left the CMOS battery disconnected for a day.
You need to contact HP to get this resolved.
http://h30434.www3.hp.com/t5/Notebook-Op...
Wm Brian Savacool - Responder
This didn't work for me
Depinder Bharti - Responder
I can't even boot
Hugo Escobar - Responder
cool i like the explanation
Nartey Levis - Responder
Τελικά μπορούμε με κάποιο τρόπο να αφαιρέσουμε κωδικό πρόσβασης BIOS για την HP EliteBook 6930p????
Αν όχι μήπως θα λειτουργούσε ένας δίσκος λειτουργικού γραμμένος από ένα άλλο HP EliteBook 6930p ώστε να μην χρειαστούμε πρόσβασης BIOS?????
ΠΑΝΑΓΙΩΤΗΣ ΓΙΑΝΝΑΚΑΚΗΣ - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 44
Últimos 30 dias: 269
Duração total: 31,778
