Ir para o conteúdo principal
Removing the HP Elitebook 6930p Hard Drive
O que você precisa
  1. Removing the HP Elitebook 6930p Hard Drive, Battery Removal: passo 1, imagem 1 %32 Removing the HP Elitebook 6930p Hard Drive, Battery Removal: passo 1, imagem 2 %32 Removing the HP Elitebook 6930p Hard Drive, Battery Removal: passo 1, imagem 3 %32
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Hard Drive, Hard Drive: passo 2, imagem 1 %32 Removing the HP Elitebook 6930p Hard Drive, Hard Drive: passo 2, imagem 2 %32 Removing the HP Elitebook 6930p Hard Drive, Hard Drive: passo 2, imagem 3 %32
    • With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed.
    • Lift the left side of the bay cover and swing it up and to the right to remove it.
    • Loosen the M2.5×10.0 captive screw that holds the hard drive in.
    • Grasp the plastic tab and slide the hard drive to the right to disconnect it from the motherboard.
    • Lift the hard drive straight up and out of the laptop.
  3. Removing the HP Elitebook 6930p Hard Drive: passo 3, imagem 1 %32 Removing the HP Elitebook 6930p Hard Drive: passo 3, imagem 2 %32
    • To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive.
Conclusão
17 outras pessoas executaram este guia.
Richdave
Membro desde: 04/09/10
32.081 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 9,674
